S
SPARTYKUS
Lovely isn't it. i have seen more ornate versions, and kept some in one house. The casing not the VIR Cable.
it definitely shows that electricians of the past were also skilled carpenter'sLovely isn't it. i have seen more ornate versions, and kept some in one house. The casing not the VIR Cable.
ive seen one with wood female bushes and bends on copper pipe with the old ceramic ceiling roses but not in use, just left after a previous rewireNew one on me. Seen plenty VIR cables but never in wooden casing like this. Proper job that !
It's VIR wiring in wooden casing. They used this way to run it around door frames and skirtings.
http://asad31.webs.com/Asad_Wiring-system.pdf
Pulled loads of this out in my early days but it was more likely to be found in the more wealthy houses .... noted haven't seen it for decades
The Welsh valleys are not what anybody could call top end housing standard,however,the wooden trunking would be almost universal in the older terrace houses and was and still is often found in attics and under floors
It was originally used for the complete surface installation, it was the next step up from knob wiring.
Those were the days when the electrician was the bees knees of the building trade and usually wore a suit and bowler to work, with an apprentice walking not less that 3 steps behind him, carrying his tools between jobs...lol!!
