Lovely isn't it. i have seen more ornate versions, and kept some in one house. The casing not the VIR Cable.
New one on me. Seen plenty VIR cables but never in wooden casing like this. Proper job that !
Pulled loads of this out in my early days but it was more likely to be found in the more wealthy houses .... noted haven't seen it for decades
You know how I enjoy domestic installs. I got lumbered with a Victorian town house that had been converted to that new fangled electricity stuff in the 20’s.
It was all done in oak capping and casing. I kept as much as I could in situ and reused it for T+E. I even resorted to using the lead gas pipes that originally fed wall lights for these new fangled light things. Anything rather than drill behind the plaster covings.
I even found an Edison Swan “teardrop” lamp still working in the loft.
It took an age to do, half my time was spent on tea and cakes. The owner of the house was in her 70’s and believed she had to keep the workmen fed.
Sy if you can salvage lengths of that capping and casing it will sell for architectural reclamation.
It's VIR wiring in wooden casing. They used this way to run it around door frames and skirtings.
http://asad31.webs.com/Asad_Wiring-system.pdf
It was originally used for the complete surface installation, it was the next step up from knob wiring.
Those were the days when the electrician was the bees knees of the building trade and usually wore a suit and bowler to work, with an apprentice walking not less that 3 steps behind him, carrying his tools between jobs...lol!!
The Welsh valleys are not what anybody could call top end housing standard,however,the wooden trunking would be almost universal in the older terrace houses and was and still is often found in attics and under floors
That's true, Des. Wouldn't was say it was for the more affluent. I can remember removing rafts of c+c from terraced houses, painted or papered over a lot of it. When it's been in decent conditions the vir is usually in a really good state.
While I was looking (unsuccessfully) for some bumf on Octopus wiring, I found a handy article on how to make tees and crossovers in wooden casing. The rule was never to allow cables of opposite polarity to touch, so a very intricate arrangement of the bridge parts was required like a compartment trunking tee, but all made on the spot.
I'll scan the article when I get home, which might be a while (yes I am in the workshop at 4.30 am but there is much to do...)
What's knob wiring?
