M
Markymark981
Ok thanks am I missing something with ththe smoke alarms been on a 6a fuse?
An old lecturer told me don't worry too much as at worst it'll just blow the main fuse but I'm not entirely comfortable with that response
As for the emergency lights, is the customer suitably qualified to make that decision? Do you understand why putting them on a seperate circuit may be a bad idea which you, as the installer, could be liable for?
Great advice that. 'Don't worry if demand is a bit too high, it will just knock out the entire system and need the DNO to come and fix it'. Makes you wonder why we bother working max demand out really. Daz
Hi dave this is the first time I have been asked for emergency lighting I've checked onsite guides and it didn't mention anything about them been on either a separate circuit or the lighting circuit, I just did it on a separate circuit for identification on the cu
would I be ok to connect the emergency lighting into the same mcb as the downstairs lights if they don't pull much power?
sorry to ask so many questions but these two topics (emergency light and demand) I've not had issues with in the past
cheers mark
cheers mark
Think about it. Emergency lighting is there to be activated and provide lighting when the main lighting fails.
i understand but each floors as its own circuit and the hall and landings have their own circuit so could I join the hallways and emergency lighting feeds into the same mcb save me having to go back and re wire?
