It's interesting that H4 in the OSG starts with this statement: The circuit [cooker circuit] supplies a switch or a cooker unit if any, complying with BS 4177, which may incorporate a socket-outlet.
Examining the language used, I'd suggest the meaning of this is clear. It doesn't make any allowance for there not to be said unit, so it considers it to be mandatory. Cookers are unique in a way, in that a lot of the things which go wrong with them will not cause electrical protection to operate, and so emergency switching is not only desirable, it's arguably necessary. Chip pan fires, for example, will destroy your house but not trip the MCB on the cooker circuit.
What seems so often disregarded is this; BS7671 is not the law, not statutory. However, try ignoring either BS7671 or any of its attached documents and then argue in court that you didn't need to pay any attention to non-statutory regulations, because they're not the law. See how far you get with that.
BS7671, 114.1. The Regulations are non-statutory. They may, however, be used in a court of law in evidence to claim compliance with a statutory requirement.
It's not hard to imagine the converse being true, that is that non-compliance with BS7671 may be seen as non-compliance with statutory requirements. In other words, it's not hard to imagine an argument being advanced that, since fitting a cooker unit makes such eminent sense that failure to fit one on the basis that it's not specifically required in a specific Regulation, would itself be unreasonable or negligent.
I'm not quite sure YS how you are looking at this. It says as you say in H4 but the cooker thermostats on the oven and the hob switches are control switches, so they will conform to the guide.
Table 53.4 shows us numerous devices that will give you isolation, emergency switching functional switching so it won't just be a cooker switch. The crux is should you have this isolation, emergency switching functional switching local to the Unit, and that logically is desireable, but not essential
I can't see how you can argue the point that if you do something in the regulations then by abiding by that regulation you could be prosecuted. There is nothing stopping someone exceeding the regulations and that will always be acceptable and can be argued.
By the same token you can not be held accountable by abiding to a regulation, whether you feel that the regulation is wrong of not.
I understand where your coming from, but the regulations are there for the whole and not just the part. I was always told you get 10 sparks in a room and you will get 10 different ways to do a job and that is so true.
In that context what you feel is wrong by omitting the cooker switch, another 4 will say no that is OK as per the Regs. The IET really don't have that comfort. They have to produce a standard document with what they believe is safe and to a standard, and on this they feel that it is to a standard
The argument I'm making is based on experience of H&S prosecutions. As I said, it only needs a judge to be persuaded that to leave a cooker without the means of emergency switching is unreasonable for him to find negligence. It's no good going to stautory requirements because they don't mention cooker switches, but he only needs to find you were acting unreasonably to convict you. Please understand I'm not arguing for or against the installation of cooker switches, although I do have an opinion on that. Let me put it another way. If our OP was aksed in court if he thought it was unreasonable, or even unsafe, not to fit the switch where it can readily be reached, and he replied in the affirmative, he would then most likely be asked why he did it anyway. That in itself would probably be seen as an unreasonable thing to do. That's what might drop him in trouble. Is that any clearer?
"By the same token you can not be held accountable by abiding to a regulation, whether you feel that the regulation is wrong of not."
The trouble here is that we're not talking about abiding by a regulation. Instead, we're talking about not doing something which isn't necessarily covered by a regulation. The legal world is full of examples whereby liability is found even where there is no specific statute covering an alleged tort, simply because a judge decides that a reasonable person would or would not have done something, regardless of the legal niceties. It is what it is.
Your quote contained the words "if any". This would not suggest it is mandatory.
Nevertheless, the On-Site Guide is not the IET Wiring Regulations and should not be considered so to be.
In previous editions of the regulations a cooker switch was explicitly required, this regulation has been removed at some point in time and does not feature in the current edition.
So somewhere along the line a conscious decision to remove that regulation has been taken, so it would be logical to make the assumption that it has been deemed to no longer be necessary.
Ok, but how often in the real world do you actually come across a cooker that doesn't have a nearby isolator ? I'd be surprised if I did, and such switches are even commonly referred to as 'cooker panels'.
I've got one customer who has a couple of ovens without isolators. I've never been particularly happy about it as the only way to isolate is to pull the three fuses out of the old MEM excel board they're fed from.
There's the same problem with the extractor fan, again you have to pull the three fuses to isolate,
The last mention of a cooker switch was in the 15th, where a single switch could be used to control 2 cookers, as long as both cookers were within 2m of the switch.
When considering whether to install a cooker switch, the reason/s for doing so should first be considered, and all requirements should be complied with.
I'm sure I've seen that in more recent editions
