K
Karl91
Hi guys,
I've been offered a job as an apprentice and start in a couple of weeks.
I want to make a good impression and turn up with my own tools. I already have things like side cutters, plyers, levels, a set of drivers and a lock out kit from my old job.
Could you give me a list of tools including drill bits etc I will need to have as an apprentice ([FONT=arial, sans-serif-light, sans-serif]preferably[/FONT] affordable!)
Cheers
To be honest, drill bits and other consumables such as hack saw blades and electrical tape should be provided by the employer.
That aside drill bits you will find useful are:
Masonary 5.5mm, 8mm, 10mm and 12mm.
HSS 3mm, 6mm (1/4), 8mm, 10mm and 12mm.
Hole saws 20mm, 25mm and 32mm (will need others for down lighters of various sizes).
Wood bits 8mm, 10mm, 12mm, 15mm and 22mm.
Hi guys,
Could you give me a list of tools including drill bits etc I will need to have as an apprentice (preferably affordable!)
Cheers
What areas of work will you be engaged in ?
If commercial/industrial then a set of combi spanners, decent hacksaw, set of files, pairs of slip joint pliers, bush spanners etc would be good ideas.
If solely domestic work then you might never get these items out of your box.
If shopfitting then you will need some rolls of tape, tie wraps, a javelin to sling cables above ceilings, and a fast van to leg it in.
I would say a decent voltage indicator, tape measure, hacksaws, lump hammer, scutch chisel and bolster, would be a good supplement to what you already have for an apprentice.
If you have to borrow something twice in a day, you need one of your own.
and a bloody spirit level. apprentices can be the worst going for fitting things pi$$ed.
M3.5 rethreading tool, pad saw, tape measure, Hammer, club hammer, bolster, cold chisel, martindale / socket tester, hacksaw, voltage / continuity tester, Stanley knife, water pump pliers x 2
Edit: I didn't post the link....you can get one for a third of that price.
And a long stand, although you should be issued with one of those.... don't forget to ask about it.
don't forget one of these ;-)
A good memory for when you are taking the tea and coffee orders!
good luck matey (and don't fiddle with your mobile too much)!
Nice one chaps that should help me get a few extra things together. I've got the teaspoon covered!
Do you suggest I hold off on drills etc atm then?
Drills, much like saw blades, grinder discs etc. are consumables, they should be provided by the employer.
