J.C.E
Evening guys
I know price talk can get a little touchy- so I have stuck in arms..
Obviously only say if you feel comfortable..
customer doesn't want full eicr carried out prior AND THEN cost of c\u change
(so just few pre change global IR tests and end to ends etc)
bonding/earth/tails adequate already
10way dual RCD- known brands (wylex, MK, hagers etc)
EIC issued and part p'ed
what you guys charging and what area?
I am about the 350quid mark and surrey base- thinking of upping to 375/400 with adm3 boards
what you think guys
Evening guys
what you think guys
£400 for an amendment 3 board is about right IMO. Done on recently £490 for amendment 3 board, gas and water bonds 4 meters away in next cupboard.
I'd say that's about right, I'll charge around £350 including the new Amd 3 board unless it's a particularly tricky/large CU.
It's definitely a good days work IMO to do it properly including all the tests and filling out the certificate so for me around £250 clear is a decent earner. [I'm in Cornwall].
I always allow a full day, irrespective of whether the board is 4 way or 10 way. That way the client gets the job done without a rush and no corners cut. Even if I leave site at 3pm, the paperwork will always completes my day.
So thinking about AMD 3 boards is minimum £400 for me plus any bonding etc.
Evening guys
what you think guys
I'm your way and also charge £400 for a basic change, anything like bonding etc obviously go on top. Quoted a house not long ago with loads of outside lighting, nothing bonded and nothing labelled. Upped quote to £500 (which I didn't think was too bad) and the client then didn't like that the price had gone up or my reasons for it, so went elsewhere, which is fine with me!
Used to charge £350, but have quoted £370-400 for A3 board (dependent on price I could get CU from wholesalers). MK A3 boards seem to be getting slightly cheaper, fully populated 10 way about £120, whereas Wylex e.g. about £160 (last I checked).
can get a fully populated 10 way MK A3 boards for £70-£80 inc VAT
Trouble is, they can wander through B&Q and see a lovely CU for £60!
Edit; £40 now
makes you laugh though when you see plumbers charging £2000 for a combi change that takes him less than a day and can pick the boiler up for less than £800.....
