Having lived and worked in France for 12 years before returning to the UK 2 years ago, Wago's are old hat to me. Over there they have been around for over 5 years and are much smaller than the UK version, but in all the time I have been using them I have never had an issue with them.
do you use them as they are or do you use them with the enclosure
line products enclosures are the dog's danglies. 2" round fit up any downlight hole.
Does anyone ever use the wagos for RFC? I get they can hold upto 2.5/4.0. But are they rated for RFC's?
The lever type are rated at 32a, the non lever only 24a. Ideal do a similar product that are all rated at 32a as far as I'm aware. Wago do a larger connector too for 4 or 6mm cable.
out of curiosity does anyone use them ideal twist one's?
Got some 'free' in a set of assorted Ideal 'in sure' connectors, I'm very wary of trying them though as twisting cables together seems a bit dodgy to me - then again I've seen hundreds of the old porcelain 'screwits' in JBs over the years which haven't gone wrong- all on lighting though. These new 'twisters' are allegedly rated at 41 amps !:confused:
wirenuts or screwits are designed for stranded cables, not the solid core shyte that we're palmed off with these days.
Haha! I seen a sparky who is now working for the same guy i used to subby for using them, they looked awful, twisting your conductors together then screwing one of them on, watching was nearly painful, i like my terminations neat, they are far from it!
