HappyHippyDad
Supporter
I am looking for the best way to shrink heatshrink (cordless)?
I have used the Iroda micro-therm which was awful so I bought a heat gun to use instead, see pic below. However, I find it too much for heatshrink and after a few seconds (even on low setting) a flame envelopes the heatshrink, although this doesn't damage the heatshrink I would like more control.
I notice a gas soldering iron is mentioned and this is what I am erring towards, is this effective? Does it take ages or is it fairly swift? Any other suggestions, flameless heat gun?
This (below) was mentioned by Lee in a thread but looks as though it takes ages, anyone with first hand experience?
https://www.amazon.co.uk/Draper-787...dp/B000ELJ0EC?ie=UTF8&ref_=pd_lpo_sbs_dp_ss_1
Cheers.
I posted a few weeks back, asking for similar advice; http://www.electriciansforums.co.uk/electrical-tools-products/109074-hot-air-gun-heat-shrink.html
In the end I bought one of those crème brulee torches, got one from Currys; Buy KITCHEN CRAFT 20 MC Professional Blowtorch - Silver, Black & Red | Free Delivery | Currys
Fine with heat shrink as long as you turn the flame down low, burnt a few puddings with it as well :frown2:
Thanks Midwest but that looks eactly the same as my present heatgun (see pic above) which I'm not too keen on. It shrinks it very quickly but after a few seconds envelopes it in flame (even on low setting) so I would like something less powerful.
Cheers.
If you have the flame that high, its gonna melt the copper cable, let alone the heat shrink :cool3:
I use a similar thing, used it today as it happens. I even used it the other day to soften the old vinyl on the old van to peel it off.
i used to get the ex-wife to breathe on it, but then she got a new job in cardiff, as a model for the welsh flag
Yes , Portasol gas iron will do that too. Plus you have the advantage of a versatile Iron.
Google pencil torch or windproof lighter. They're less heat output than the blowtorch in your opening post, I also find the chef's blowtorches to be too hot unless you're using it on big diameters like 50mm and over.
I usually use a miniature propane torch which is about the size of a largish cigarette lighter, something like this images.jpeg.
You can actually use one of those windproof lighters for the smaller heatshrink sizes.
Blow lamp with a regulator on it never any problems
Similar to this turned down low
You can you's it for plumbing to
Sent from my iPhone using Tapatalk
With the gas torch generally they are very limited on flame / heat adjustment
it's easy to burn the heat shrink if you you don't move the flame about,
I tend to keep it moving but aim off to the side of the heatshrink, but a heat gun will do exactly the same on a high setting,
Using low setting can take a bit more time
Personally I prefer the small creme brulee type
I've also just bought a small cigar lighter in china which you can angle the head it's all made of metal and holds a lot more gas than the plastic version I have also has a cap on a chain which is a bit of a nuisance but when fitted the gas cannot be ignited so I'll keep it attached just for the safety aspect
Sent from my GT-I9195 using Tapatalk
HappyHippyDad
Supporter
Gloucestershire
Gas soldering iron for heatshrink?
Electrical Tools and Products
HappyHippyDad,
edexlab,
