K
Kevin Yates
Hi All,
I am looking some advice regarding what device/s would be required to do the following:
I have a fairly heavy duty UPS (APC 2200VA, supports max of 1980 Watts - it's pure sine wave if that makes a difference). There are a few electrical items attached, totalling no more than 150 Watts at the most.
I also have a lighting circuit, which is all on one 6A breaker in the consumer unit and consists of various fixtures and fittings, all LED and totalling no more than 350 Watts if all on full.
What I want to know is what would be required to either have the supply for lighting circuit switched to the UPS upon grid power cuts, or be able to manually switch between grid power and UPS backup for the lighting?
Thanks in advance
Thanks in advance
