R
rossfenwick
Afternoon,
I've just been to a new build finishing off some lighting and found a fault in the 3c&e between the landing and hallway. No continuity on 1 core.
It's going to cause a lot of damage to replace the cable. The other 2 cores & CPC are good, IR tests fine.
Is there anything out there wireless, everything I have seen looks to still need the 3 cores between switches.
Suggestions welcome!!
if so, than the cable to the hallway to of the stairs needs replacing.
then is down to plasters to repair the damage .
How do you know it was the plasterer's fault in the first place, Buzz highly likely but is there, be any proof.
If it's new build there is no plaster , they board the walls and tape the joints then sand down.
No plastering involved
Afternoon,
How old is the property? is it still under warranty?
Yes, so? all I asked was how old, and is it still under warranty fair question I think and why so fractious with your post?
Not being fractious, I thought you missed the new build part of the post the op posted.
Chill out yeah?
