Discuss Whats your thoughts on this in the UK Electrical Forum area at ElectriciansForums.net
There looks like only the one CPC.Just a thought...if a L comes adrift when you take the socket off...that backbox might be live...but if the guys fitting them have only ever encountered plastic, drywall back-boxes, they may not realise the consequences...and if so, they have no place wiring them in, in the first place...in which case, they have clearly had insufficient training.
Mr New House Owner might indeed fit shiny chrome faceplates, and assume the existing chocblock CPC termination was all that was required...
Bloody new-builds...well, you all know I hate 'em!
Plus, it isn't difficult to get 4 CPCs in the earth block thingy, or crimp them...
but then, I am not an electrician, so will put my hard hat on...
Thats for cheap sh!te........and why pay £300k for ****?
(He added, as an afterthought)
Or pay a competent person in the first place, mistakes should be rectified.Won’t be that hard to push when the alternative is paying for someone to go round and check every light switch and make good any damage to the finished decoration.
Unfortunately, it seems to be becoming the norm to employ unqualified workers for most of a job and finish off with a couple of qualified.Or pay a competent person in the first place, mistakes should be rectified.
Part of the problem is that the prices & time scales to do these houses is so tight that every opportunity to cut corners is taken. The caulk round the accessories is probably not the electrical contractors fault. Everybody is on a tight schedule and adopt the attitude "its not my problem".Glad everyone is in agreement.
Like i say every switch is like this. Reckon Its done because they have trouble putting 3 or 4 Cpcs into the earth terminal of the KO box, a fly lead would obviously waste valuable time...
Thing is all the time the plastic screw caps are on it compiles even though its dogs mess !
Edit....
I forgot to add, every switch has decorators chaulk round it too.
Walls are just taped, jointed, and painted.
Cheap as chips.
Has to be vertical.I like to line up the fixing screws either vertical or horizontal, but that's because I'm a bit ---- when it comes to the aesthetics. Also you know if somebody else has been messing after you have fixed it back
also the wall should have been painted before the face plates had been attached, paint on the face plate nasty paint lines going around the aperture.
Im hope your right.
I was told this by an NIC inspector in February (i know, i know) it came up as it was around that time that i noticed click started providing the caps on their accessories.
Reply to Whats your thoughts on this in the UK Electrical Forum area at ElectriciansForums.net
