Anyone got any advice on the toughest screwdriver tips available. I’ve just bought the new Milwaukee (supposedly) impact resistant bits but they don’t seem to be lasting very long before they need replacing. I’m drilling into steel with techs as well as wood which obviously isn’t ideal with an impact but they should still be lasting longer than they are. Any advice?
I dropped 40quid on a fancy set of wiha bits. They've been less prone to shattering in the impact gun, but still wear out faster than I hoped.
Sticking with the cheap tic tac boxes of dewalt or bosch now and just treat them as disposable.
All my Milwaukee impact rated bits are nowhere near as strong as I hoped. I have a Bosch PZ2 that I have had for ten years now and it's better than some month old Milwaukee bits.
I've a Milwaukee impact rated bit holder, it's a pile of poo. In my helpers impact driver is a non impact rated CK one - it's older and in far better nick than mine.
The impact rated Milwaukee bits are made of glass I think.
Yes the Milwaukee bits are not great to say the least. I always try to use the correct bits for the screwhead, obviously occasionally this is not possible but 90% of the time I’ll be using matching. The wera impaktors seem to be the general consensus. I have a few wera tools kicking about and tbh they are all very good quality. I’ll give them a go and see how I get on. Thanks for all replys
Would you guys suggest using the matching bit holders too or does it not affect performance either way? I need to get an extension bar also
They are all the same size so its down to preference. I use a Millwaukee bit holder and its been fine for a couple of yesrs now and some abuse both physical and verbally, I even use my impact driver for spade bits too as they fit.
The bits you get in a box of screws for use in an impact screwdriver are pretty strong as they have a forged tip.
Yes, but you only get one per box of 100, and running around asking dry liners if they have a spare bit is a little unprofessional.
Andy78, I'm so pleased to get an agree from you, so there's at least two of us who manage fine without the latest must have cordless tools. :D
I've got some pretty up to date cordless, I think that's why I don't need an impact :D
Mate of mine rates his impact for ploughing through joists, but that's only because his combi can't handle the job.
I must agree that impact drivers are a bit of a fad right now. I think joiners popularised them and now everyone thinks they need one.
joiners only use them because they learnt that a an impact drier saves hammering screws in with a 2lb hammer
I first had one 13 years ago before anyone had heard of them, shown them to some joiners who were using 14.4 volts drills to make some timber stud work with 4 inch screws, didnt beleive they would be upto the task until they used it. I hardly used it back then although think that was mainly down to how much it cost
They have alot more torque than using a drill/driver. Meaning the screw will go into the fixing point a lot easier.
Also because it uses very short, sharp blows to drive the screw in, the bit doesn't cam-out and damage the screwhead like a normal screwdriver which makes them especially useful for removing tight screws.
I use an 1/2 inch drive impact wrench with an adapter for screws. It's also very good for removing elements using large sockets from water heaters and air handling units. Also a big time and effort saver for large coach screws into raw plugs in concrete walls etc.
I have been having fair success with DART bits of late.
I do find that, as with TCT masonry bits, if you allow any "chatter" between the bit and the screw then bit life is significantly shortened regardless of which brand is used.
I buy whichever multi bit set is on offer in the Christmas deals at my wholesaler and that lasts me for a year. I do the same with Stanley knives.
I have small makita white 10. something v impact driver it's small, light and drives in just about anything I need it to.
Better for getting tight screws out than a drill or hand driver.
Leigh on sea
Toughest screwdriver bits
Sparksaflyin,
ferg,
