R
ringer
Just read on another thread about the use of impact drivers for rawlplugs. The kind of impact drivers I'm familiar with are big metal hand tools for loosening stubborn nuts, bolts and screws. So what is this other kind of impact driver? Is it a fancy cordless screwdriver? What is the advantage over using a drill with a screwdriver bit?
So much easier I brought one from b and q performance power £50 bet thing I ever done
It is designed for one job, to drive screws in without destroying the screw, a typical 18v drill will produce about 500 inch-pounds torque, but an impact driver around 1100, good for tightening most screws and bolts, although in my experience you should use a good quality screw bit like the Wera impact driver bit set, designed for the job, some cheaper brands can round off fairly easy, of course this is also down to operator
I brought a makita set and got an impact driver thrown in. I now use it all the time and my 18v combi is hardly ever used.
I was the same as many and didn't see the point of them until I got one.
Eddie can I ask a stupid question. During a normal day what things do you use it for?
I only ask because I am in the market for a 1st fix air nailer and am thinking if this can do the same sort of job I might just buy the dewalt 18v one. Bit easier than dragging a compressor etc etc around.
Depends mate , if I'm putting up tray and unistrut I use it for the hex nuts and bolts.
I use it with an auger bit that fits, but would not recommend too many,
And general screwing,
I normally have my 36v Bosch with me to do the heavy work.
But I want a nail gun too but can't justify if yet but trust me I will find a way.
The DeWalt 18v impact driver is superb and you can get an adaptor to use it as an impact wrench. Use mine all the time
I use a 10.8v Bosch professional impact driver. It drives screws in well, weighs 1kg and fits in my pocket.
Yes you could just use a drill, but a drill is bigger and heavier.
I use my impact driver day in day out, absolutely brilliant, wouldn't drive screws in with anything else (am careful in plasterboard and wouldn't use on plate screws). Saves time and therefore money, have never rounded a screw yet!
I have a Bosch Lithium 10.8v impact driver and a Makita 18v Lithium impact driver and would not be without either perfect for screwing into plugs, wood or using as a nut driver.
I have had them both for at least 3 years and they are both still going strong.
The bosch is ideal for scewing back boxes and brackets up etc as it fits in the pocket of my snickers perfectly and weighs next to nothing and is ideal when your up a ladder or in a tight space.:D
Cheers Chris.
