Packing out back boxes
That's what we call it too. Same stuff . :)
All these new fangled compounds, knock the knock outs you require, fit Grommet slap it in the hole, slap the box in, level it, fill in around the box, job done.
Well I'm going to show off now and say I have never had to do that :smirk:
When I see the brick/stone crumbling behind the back box I do the following...
1. Panic.
2. Slowly stop panicking.
3. Slow everything down and become very gentle with the remaining brick.
4. Drill new holes in the back box itself if needed, where I know there is good brick behind.
5. Drill out new holes in the remaining brick, starting with a smaller drill bit and working up, preferably not with hammer action.
6. Huge sigh of relief when 2 of the screws take a firm hold!
7. Cup of tea.
1. Panic.
7. Cup of tea.
Compo every time
I tend to use drywall mix for the odd issue like this, I find the thistle and the knauf stuff the best. The half hour set stuff is really good for quick patch too, low shrinking and you can finish it up with ease too!
Had that the other day on an old cottage, rcd kept tripping low n-e insulation resistance found it on a badly corroded socket and box IMG_20190318_1651435.jpg
