Guest viewing is limited
All, evening to you. I’ve started using electraform for doing certs. Doing an EICS and in the test results part there is a column next to measured Zs marked measured kA. I might be being special, but I’m not sure what I’d put in here for each circuit. Looking at my spare manually completed forms, this column doesn’t exist. Am I missing something? TIA
Yep, that makes sense: but the form is definitely an EICS, so is it asking me to give an PEFC/PSCC for every circuit. Done the PEFC /PSCC at the DB and that is annotated on the form. Just find it a little baffling.
The 18th edition model forms, have a column in the section for protective device details, for Breaking Capacity (kA).
No column for measured kA.
I have been using elctraform and noticed this, but from what i can tell it doesnt appear on the printed final pdf version?
Here are the pdf pages of the test results, i print them off as blank to use on site before entering online at home.
Haworth
Measured kA on electraform EICS
Sean McD,
Gavin John Hyde,
