Discuss Measured kA on electraform EICS in the UK Electrical Forum area at ElectriciansForums.net
All, evening to you. I’ve started using electraform for doing certs. Doing an EICS and in the test results part there is a column next to measured Zs marked measured kA. I might be being special, but I’m not sure what I’d put in here for each circuit. Looking at my spare manually completed forms, this column doesn’t exist. Am I missing something? TIA
Yep, that makes sense: but the form is definitely an EICS, so is it asking me to give an PEFC/PSCC for every circuit. Done the PEFC /PSCC at the DB and that is annotated on the form. Just find it a little baffling.
I've never seen it either and am probably wrong but I fancied poking you with a stick anyway. :D
As a side note I'm sure you are ahead of me on the old and codgering front. :p
I have been using elctraform and noticed this, but from what i can tell it doesnt appear on the printed final pdf version?
Here are the pdf pages of the test results, i print them off as blank to use on site before entering online at home.
Reply to Measured kA on electraform EICS in the UK Electrical Forum area at ElectriciansForums.net
Eh up :) I've done some new PDF forms for BS7671 18th Edition Amendment 2 2022 (the Big Brown Book), based on the IET model forms. You can fill...
12K
I’d like your opinions on a scenario I’ve come across. A certificate was produced which contained errors and while there were still faults on the...
Hi. I have a problem I’d like some advice on, please. If you just want to know the question please go directly to section B of the following. If...
Recently I got a DL9118 multi-function tester and one of its capabilities is, of course, measuring Zs. But I wondered how it worked in terms of...
To keep your trainee brains in tip top condition during lockdown, here's a few quiz questions.... 1) A fault report is 'Circuit breaker keeps...
