Center tapped 240 is 120. Line to line 240 produces 138.
Republic of the Philippines uses this system.
Yes, BS7671 and IEC codes on how they would go about dealing with those two voltages.
I'm well aware line-line 240 is rare in Europe.
Its ok. :) Just this forum is to quick to assume things.
In a star connection phase to phase is 240 vac phase to earth 120vac the voltage you read can be as high as 130vac the same goes with 3 phase. It’s a plus or minus 5% on the voltage in the US
138-139 volts, at 252 volts (+5%) it is 145 volts.
130 volts would be the highest in a 120/208 system, not a 240 volt wye system.
The drawings are correct for the system being depicted.
Also got a post deleted in another thread for saying the stuff on Amazon made by China is often not safe to install.
Tricky tight rope - Negative opinions ..
( I'm older and just love moaning )
You get what you pay for, (and some local wholesalers risk a big hit , when they have to honour their returns policy)
Need to educate customers to spend more!
On paper is one thing, in the real world it’s a totally different world. Why the emphasis on exactly 138vac
