L
Leccy monster
Hi everyone
I'm a DIYer with little electrical knowledge looking for some advice I'm currently building a sterilisation cabinet with a UVC light in it. The cabinet is a Wooden box with a hinged lid I plan to use a microswitch to cut the uv lamp when the lid is opened.
Am I correct to think I can have a power lead coming in to a connecter block, take the + wire to the microswitch and back to the connector block and then take all wires + - and earth from connector block to the ballast unit? With the earth then connect to the ballast? Or would I need some special arrangement to earth it? The ballast unit will be mounted on the box and the earth will connect to an earth port on the ballast unit would this be sufficient to ground the circuit? See sketch.
All help much appreciated!
