Those look like JG Speedfit elbows.
You can open them up, and re-use without replacing "O" rings, but i would only do that once, otherwise just replace...there's no room for being stingy, just replace as necessary.
Also, B&Q sell many different types of pipe and fittings...I used some of their grey ones 20 years ago and they are still fine, but I do believe it is crucial to keep the same manufacturer for pipe and fittings as there are tolerances which are important.
Also, just a minor point, I always buy the longest pipe in straight lengths available. The coils are a fkn nightmare, unless you are doing very long runs, in which case they are invaluable.
Just been out to a job where the guy was screwing down floorboards and punctured the hot supply twice and the cold supply once...it's secure now, for a day or two, but I will have to return to fix it properly. Under a bathroom floor which is tiled...say no more!
Thank Rothenberger for Kibosh!
View: https://www.youtube.com/watch?v=JkNsL6CDdXk
Yeah you can re-use the JG speedfit without opening up and replacing o-ring, I have used load and loads of there stuff as I re-plummed my house. In the places where you can see the pipe work I did nice solder joints, But in the crawl space where you can hardly move, its has to be speed fit.
If it replace all of the copper down there for plastic I am not gaining that much really, unless I take the pipe on a little tour of the back of some kitchen units to make it a bit longer, at the min I think it has 3 or 4 elbows and a speedfit isolation valve (plastic also)
[automerge]1587497942[/automerge]
The strange thing is, why is the outside tap resistance less, when there is more plastic then used on my test piece
Dont think it is water under pressure as iv measued it with the tap on and the tap off
Very strange, it is copper though the wall, but i cant think what it would be touching though the wall, i drilled the hole and it was easy, didnt hit anything suspicious
How long have the plastic pipe fittings been in place?
It's possibly deposits from the water on the inside of the fittings decreasing the resistance
Ahh good thinking it might be something like that. probably between 6 months and a year
I might swap out one of the elbows tomorrow and do the same test on the bench with the older (deposit built up) elbow and see if there is a difference
If you are replacing any section, I would go for the one through the wall to the outside. You get the biggest electrical isolation advantage (as inside unlikely to have a risk to ground even if PME raises the earth potential) and most likely frost damage is outside (plastic less likely to rupture than copper).
I see little advantage versus cost/effort for the rest.
If you are replacing any section, I would go for the one through the wall to the outside. You get the biggest electrical isolation advantage (as inside unlikely to have a risk to ground even if PME raises the earth potential) and most likely frost damage is outside.
Cant replace that bit unfortunately as it is a hose union backplate like so:
I would love to have a plastic version, but have had a quick search and cannot find
Tricky. You could take the pipe out, 90 deg bind then something like this:
Not as neat & elegant though.
Or just replace the 1st copper section after it comes through the wall.
If you are measuring impedance from tap to Earth you might well be seeing some parallel resistance in the wall. You would need to measure tap to 1st copper section after the plastic bend (floating from Earth) and even then as already said there might be deposits inside making resistance lower than the water alone.
Yeah not as neat, its nice being flush to the wall but I see your point
Yes that is a good test, I will try that between tap and next copper section inside. If it is the case there is parallel resistance in the wall, would that be beneficial in a PEN fault (seems crazy brick wall could conduct) although the bricks were put there in a long time ago and they are the breathable kind so iv been told (house was built in 1840)
Outside Tap Kit 15mm x ½ - https://www.screwfix.com/p/outside-tap-kit-15mm-x/33139
Could try that if not, however, I don't much like the idea of mains pressure water connected with a hose and jubilee clip ! (or the self cutting idea)
I usually fit outside taps with plastic pipe through the wall. OK, it's not flush, but you simply use a 15mm compression elbow, then a short length of plastic pipe to another compression fitting into which the tap screws. The bib fitting needs to be spaced off the wall on a piece of wood. The whole assembly is more resistant to frost, and i fit stopcock internally, so when winter comes, switch off, take tap away, exces water drains out...and in Spring, it's 2 minutes work to re-assemble.
[automerge]1587506056[/automerge]
[automerge]1587506090[/automerge]
Compression fittings on plastic pipe are your friend!
[automerge]1587507283[/automerge]
Here's a pic...on this occasion I used a copper "stub" pipe, but the pipe through the wall is plastic. It's mounted on a chamfered teak backing plate. To me, it just makes sense to have a plastic pipe through the wall, and internal coupling is easier.
That looks an awful lot like you've put PTFE tape on the threads of a compression fitting?
Thats a waste of time, and usually a sure sign of someone not understanding what they are doing.
Thank you for your comments davesparks!
Let's just agree to differ, ok?
There are times to use PTFE, and times not to use PTFE, and I suggest maybe you have not considered your response, but merely butted in with a comment that you believe to be correct.
I stand by my usage of it where circumstances indicate it is useful, and your suggestion that i don't know what I am doing is a little bit insulting.
I have plumbed scores of kitchens and bathrooms, used alternative methods where required, and am quite confident that the lack of problems means my methodology is fine, thanks.
I fully believe there are folks who will agree with you, and some who will not, but the simple fact is that PTFE is a perfectly acceptable adjunct for compression fittings, and without it many installations would fail. There are some who scoff at the use of Calor-Tite, but who owe their lives to that stuff...just don't dismiss the practices that us old codgers adopt, ok?
If you face a leaking joint under your floor, tell me you wouldn't try some PTFE as a first defence.
This isn't leaking electricity that can kill you, it's a sealing tape that can stop a leak, allow alignment of joints, take up some slack, allow for some extra tightening, and provide a better seal than metal to metal can provide in some circumstances.
OK, not perfect, but useful and perfectly acceptable in most (not all) circumstances.
I believe that quite a few people use it, and it was designed to be used with compression fittings, which are fairly common.
Finally, stating that I clearly don't know what i am doing is not helpful. This forum is for assistance, not criticism. I try to contribute where I feel i can, so if you have a constructive response to make, i look forward to hearing it.
But you've put it on the threads, which do not directly form part of the seal so do not need any form of sealing material applied to them.
All of the sealing is done by the olive, the threads are purely there to allow the nut to compress the olive.
Sealing compound should be applied to the outer surface of the olive, and a wrap of PTFE there does work if that's all that is available.
PTFE is used on threads which form a seal, such as in screwed iron pipe joints, tapered thread connections etc.
The insult was intended.
Doing something incorrectly a hundred times over does not make it correct.
