personally tried a few lasers. if other trades are on site, they'll get knocked over. esp if wet pants is there they get nicked. spreads will slop ther muck directly into the lens. sweeper up will get it covered in dust.
i use string. nobody to damage it, nobody will nick it, and you don't have to bugger off for batteries when they go flat.
I have a Huepar one from Amazon £45 and it is excellent, really clear line all round, will do 12m just in sunlight. In the dark it will easily do it! No stand though but it fits on my camera tripod with no adaptors.
Green is the way to go but the built in magnets of the dewalt one are a great asset.
I have another which has separate magnets and bracket and just a real pain to use/set up.
When laying tiles (I know, I know) using the laser to position a needed hole or cut and dry fitting the tile enables accurate positioning the required cut, especially with large format tiles. sorry for the thread drift, but thought it may be useful information.
About 18 months - 2 years ago, the 'middle of Lidl' was selling self leveling cross line lase cubes for about £18, and the thing is absolutely fantastic! I've been using it daily and it hasn't missed a beat. It's bright (I've used it over about 30m outdoors at dusk), and it gives repeatable results. I've checked it against a VERY expensive Lieca rotary, and it is every bit as accurate.
The only criticism of it that I have is that it runs on AAA batteries only, and while they have a decent life, you can't leave the thing on continuously. If it had an external power socket as well, it would be faultless.
Haven't been in a supermarket for nearly a year now, so I don't know if they've been stocked more recently.
Oh yeah. This? Parkside Cross-Line Laser - at Lidl UK - https://www.lidl.co.uk/en/p/diy-projects/parkside-cross-line-laser/p39641
£20 quid! I can see like the bosch the lines don't extend that far though so you'd need to keep moving it around as you went across the ceiling? Seems like a nice buy though.
That's the one, and the range is considerably better than 7m in normal indoor light. I've been working in the upstairs of a large farmhouse with all the internal walls removed, and it easily projects across the full 12m
