Discuss Hive help in the UK Electrical Forum area at ElectriciansForums.net
Tuharax
Hi,
I have just purchased a HIVE active heating. My boiler is a basi M90e
https://www.biasi.co.uk/assets/public/installer_literature/34/Riva Compact_Service Manual.pdf
I think I have a thermostat currently it’s always set to I don’t really use it
Heres the wiring set up
[IMG]
02821-AAA-026-E-4-C77-AF45-5-A66-FCC43-C8-D - https://ibb.co/9v7Ky2r
the hive set up
[IMG]
06388BFE 09B0 4376 A46B 0E369D87A60E - https://imgshare.io/image/prHwpt
I know it’s the bottom block I need to change. Please could someone explain which wires I put into which bits on the HIVE. Also do I remove that black linking wire? What should I fit to the earth tether. Do I need to set the boiler current clock to always on?
Matt
Hi,
[IMG]
the hive set up
[IMG]
Matt
https://community.NoLinkingToThis/threads/hive-installation-with-biasi-combi-boiler.203696/
Well I know this is what I need to do. I just don’t know what wires to buy to link to the hive to the terminal blocks. 2 core, 3 core, lead wires? No idea
Reply to Hive help in the UK Electrical Forum area at ElectriciansForums.net
