G
GBDamo
I was on the Wirral so my gaffer asked if I could swing by a pub as the landlord doesn't think the water tank is properly supported.
So I goes into the abandoned flat and ogle the surface conduit, bakerlite switches and wooden pattresses.
Then remembered the water tank.
Stuck my head through a hole in the ceiling and saw this little treasure.
Scouse plumber sense of humour eh?
Now why would you miss treat a decent copper topped table like that.
Reactions: timhoward
So what makes the landlord think it’s not supported properly?
It definitely NOT supported properly!
Ask if you can keep the table though - even if you sell it they are worth a bit!
DIY bodge job getting stripped out.
pattress box as backbox.
and wall built over faceplate screws
Seen the old plastic pattress boxes used as recessed boxes quite often , but rarely do you find a wall built over the socket
simple. the builder got there first, before rthe kitchen fitter built a cupboard over it.
quod erat faciendum
It’s a diy disaster house. Turned his hand to plumbing, joinery, ufh, sparking....
the kitchen walls here are plasterboard on top of wood panelling.
al in all.......
Reactions: static zap
When they do damp proofing and put silver back board on, ya see people use these boxes
Hope that copper table is bonded ?
Only kidding before anyone starts.
You only need airtight box's in modern house's with stud partition walls, not needed in an old farm house with solid stone walls.
Wet pants strikes again.....
GBDamo,
Mike Johnson,
