Discuss £15 vs £279 stud finder in the Electrical Tools and Products area at ElectriciansForums.net
Cheaper still is Studbuddy (careful googling that!). A powerful magnet that can detect the plasterboard screws. And if you can find them then you've found your stud.
A good tip is to use a few small neodymimium magnets to pop on the screws once you've found them. So you can see the line.
I like the idea of that little thing, but studs aren't too much of an issue. If only something as reliable was available for finding pipes and cables.
Are they a tradesman or are they one of today's so called "influencers" who quite often promote something you don't need and actually convince you that you really need it if you are gullible enough to believe them
The problem with all of these its not the things it finds thats the problem its the things it doesnt find.. In that experiment its in stud wall, I find most issues when they are chased into a wall which seems to cause more issues for these stud finders... The question you have to ask is would you trust it? Most of the time you have to use some common sense and some luck..
I bought one of amazon in the summer for doing downlights in a house. It was the really generic one sold under the name of lots of brands. Its ok, definitely useful on that job as I could get my layout for the lights and make any changes before drilling any holes.
Reply to £15 vs £279 stud finder in the Electrical Tools and Products area at ElectriciansForums.net
where will i find new electrical symbols vs celenec ?
Sensors are all around us, from the automatic doors we walk through to the motion detectors that turn on our outdoor lights. But how do these...
Trying to find an armoured cable behind plasterboard and studding. It was used to supply power from the house but has been disconnected Can...
When considering lighting options for your home or business, Electrical2Go provides a wide array of choices. Among these choices, downlights stand...
Hi. I've read much about ac vs dc but can't find a 'simple' answer. If current alternates 50 times per second in a uk mains circuit, why do live...
