W
WiredSophie
Hello everyone,
I'm not sure I'm in the right place but I was wondering if anyone knew what that thing was (see picture)?
It's on the wall above my immersion boiler and is connected only to a thermostat (but is not connected directly to the boiler).
I'm a renter and never noticed it before and what worries me is that it's extremely hot to the touch and shows yellow stains on it...must also say that our boiler runs cold water right now and is not heating up at the moment (we only have it on briefly at night).
I'm not sure if this is to do with the boiler (or a previous boiler and was left there?) or the storage heater.
All's electric in out flat and we have (ancient) storage heaters too.
Thank you,
Sophie
It is a tubular heater, probably to protect the pipework from freezing.
I would expect the thermostat to be set below 10 degrees.
Hi James,
Thanks so much for replying to me so quickly, much appreciated!
The thermostat is set on 25 degrees and our landlord handyman had told us (the thermostat) was for our bathroom heater...so that's 12 years of that thing being on 24/7 at 25degrees......arghhhhh...I'm not even going to attempt to calculate the energy and money lost there....
Would you happen to know if that thing is (was) used to heat up an airing cupboard? (cos that's where it is right now)
Thanks so much again!
Sophie
It's a tube heater. I take it this is all inside an airing cupboard?
Hi Nicebutdim,
(I feel I should steal your username!)
Yes, inside an airing cupboard indeed (that has never been used as one for years - the shelves were ripped off before we moved in.
Oh dear, we've unplugged it now...12 years of that thing being one 24/7 at 25 degrees C without us knowing....I'm going to cry.
Thanks so much for getting back to me, this is hugely appreciated!
Kind regards,
Sophie
Hi Nicebutdim,
Kind regards,
Sophie
Certainly not ideal running 24/7, but these don't consume vast quantities of power.
Difficult to tell from the image, but I'd guess it's rated somewhere in the region of 40 - 80W. Not insignificant over a period of time, but far less than one might expect of an electric heater.
Edit: I can only speculate without knowing the particulars of your accomodation, but it might be prudent to use this during spells of very cold weather.
Thanks again Nicebutdim!
It looks like it's a 60W one...
I'll keep your good advice in mind re cold weather - I live in a small block of flats.
Surprised to see one near an immersion tank that is normally a warm place.
The place was supposedly refitted and modernised before we moved in but it's been a catalogue of horrors so it's another thing to add to the list I guess.
Hi James,
Sophie
Hndyman needs reeducatingg ----
I see on the end of it, it says 60W per foot… so how long is it? 1 ft or 2ft
Seems strange to be there at all, but must have been someone’s clever idea of frost protection.
You say your boiler isn’t working? Have you got a boiler and the immersion tank?
Have you reported it to your landlord?
