There are two more pins for the address on yours A11 and A12 to address 64k rather than 16k since 2exp2 is 4.
Im not sure how your math works but here is my math:
2^16 = 65536 bit combinations (your chip)
2^64 = 1.8446744e+19 which is 2 quatrilions probably of bit combinations. And not 4 like you calculated. Haha.
16k memory locations is organised as 2048 x 8 bit memory locations shortened to 2k x 8 bits = 16k. 2exp11 = 2048. Address word A0 to A10.
64k is 4 x 2048 x 8 bit = 8192 x 8 bits = 8k x 8 bits. 2exp13 = 8192. Address word A0 to A12.
Reactions: _q12x_
Aha... I believe this number 2048 and 8192 are referring to the Addresses/or/MemoryRegisters of the IC.
I think I get your point. Im not used to think in these terms, I still lack some experience but im not far away. Thanks for your kind explanation !
Reactions: marconi
- I open it before I buy it. Im always reading the datasheet, I got used to it and is a routine now for me.
Good thought but im doing it all the time. I didnt read it corner to corner, I only fly over it, I smell it. Haha. Probably I will, in the future.
- For now I showed you that your influence grow with me. I liked the IC especially after that HARD circuit I made, also with your help, I realized it is a very good chip to have. And it was quite cheap anyway so I made the step and took them. How I will use them... we'll see in time.
Reactions: marconi
Actually there is another forum discussion until reaching this cct here. It was an entire evolution of it.
This cct is working ok but in certain parameters. It is limited to power and heat over the Tr's.
Is working fine in the 5V range for 2 of my stepper motors that I tested with it. But if Im bringing up the voltage, to 10V, I get 140dgrC on one Tr and about 60dgrC on a few others. At 5V, everything stays at a constant 50dgrC which I call it normal and safe.
One of the test motor is a Nema17 17HS4401. The other one is a scrapped stepper. Both work fine at 5V and even at 10V, no one was heating. Over 5V, especially at 10V, only the driver's Tr's were cooked to (almost)death. I stopped the power after smelling hot metal in the air.
I am also receiving a couple of L298N IC's. They are coming in the mail, not arrived yet. But I dont expect much difference from them, compared to what I have here. It would be nice to be better ! I hope so.
- My question:
- How to make this cct more powerful? To drive more power through the coils of the stepper motor? (and not blow up it's Tr's!)
I already have 2 answers to this question in my mind, but I dont want to influence your answer. I expect to be pleasantly surprised. Haha.
View attachment 102851Thank you !
Pondering the circuit at your #1, I am doubtful whether when the CD4017 output is logic 0 that the inputs to the base of the upper transistor and the input to the NOT gate are pulled down to 0V because those 4 diodes, one on top of the other, are reversed biased so no sinking current can flow through them. The diode path can only source current which raises the potential at the base and input to the NOT gate - not lower it. I would insert four 10kR resistors as I have indicated in the attachment to provide a current path to the 0V rail when the input to the diode is logic 0.
Reactions: _q12x_
-I actually did that in my experiments. Here are my results: In the simulator, I got a very small performance boost in the motor spinning. Almost negligible. In reality, nothing really looked different. With or without those resistors, the motor(s) were driven the same. I put 100k indeed there, in all my experiments. But I put 10k and 1k and the result was the same so I decided to go quite up in the resistor value since the performance and the result was equal in any circumstance.
-Your explanation is very pertinent and I like it. I may try it again and see if indeed something improves.
Well done with figuring how to draw over an image ! I know it is hard to do it for you. But it pays off, doesnt it? Heh. I cna teach you some advanced image editing stuff, since you know me, Im actually a digital artist and not someone who aspire to be one. Anytime, my doors are open to you.
Reactions: marconi
Project is finished and working !
Reactions: DPG and marconi
Well done!
You could turn it into a clock.
Reactions: _q12x_
I received yesterday the L298N stepper motor driver IC !
I am searching for a circuit with it. You are welcome to contribute with the best circuit that you know with it.
Thank you.
I was just demystifying L298N Motor Driver Module for 4 wires cct right now. It turns out it is having only a fixed 7805 VReg at 5V @500mA and 2 filter capacitors, one for the variable Input and another for the constant 5V output.
I also find this cct online, that is the exact same cct from this module datasheet, but is much more clear to me:
Then, I was also paying attention to the recommended current controller IC L6506 recommended to be used with L298 . It is a new chip for me, and I really have no idea what really does... although I read its datasheet, Im still loking stupid at it.
...further in time...
- I believe I may understand the practical reason for this L6506 IC. I believe, it is using some sort of feedback from the motor and it is --maintaining-- the same speed and torque of the motor, by automatically regulating the current.
The text selection I made is telling me what --might-- be. And I think I'm right.
- I strongly believe it is pretty much like my lathe, when I apply force on the motor spindle, when Im cutting into metal, the speed and force is maintained and not decreased as long as I press into the axe.
The simple way....
I believe...(I dont know for sure) the simplest way of driving this L298 IC is to use an arduino.
The complicated way...
Is using this L6506 IC internal cct logic. Since I dont have the chip and no one told me about it to take it in time. I didn't look very hard either in the datasheet as well.
Ive already read the entire description of this L6506 chip and I decided is a very cool function to have with my stepper motors.
I believe is a moderately 'simple' logic circuit to build. I looked at the prices already for the L6506 IC and is a bit expensive for the moment. I will live without it for awhile, and build myself its internal logic cct.
  • I think is best to do the simple way first, to get it running and familiarize with the L298 chip itself. And after that, add this new layer of cool but more complicated cct. That's the plan. Wish me luck.
  • Any helpful comments are welcome. My first time with this L298 chip. Very virgin right now. Haha.
Hello. Editing while my wife shops😕
The first thing to think about is how to provide a 35V Vcc supply of say 2 to 3 A dc for the 298 driver. Whereas the H bridge driver circuits were constant voltage drivers and the current through the coils rose and decayed as in a series resistor inductor circuit in response to an on and off voltage waveform, the 298 cleverly uses a higher voltage to increase the initial rate of rise of current through the coils which enables the stepper to operate at faster rotation rate with less reduction of torque as speed increases. The other chip has two external resistors placed in series with the two coils to sense the current through them. When the sensed voltage exceeds a threshold voltage the second chip knows the coil current I is greater than Iy the desired current through the coil and it tells the 289 to turn off the energising voltage Vx to the stepper coil. When current decays - the inductance of the coil will act to try and maintain current flow - and I is less then Iy, the threshold voltage is sensed as low and the chip turn on Vy again. For each coil, the energising voltage is being turned on and off - 'chopped' - but because of the coil's inductance the current is maintained largely constant. See my electrical art which was scribbled in the shop while I was waiting and is largely right. Obviously the full Vcc voltage across the coil would cause too much current to flow for too long and is likely to cause overheating. But the chopped waveform and the sensing of the coil current means that the average current is not greater than the specified maximum current for the coil. This quick explanation tells you why the chip is a constant current driver.
Reactions: _q12x_
Good morning. Just watched your progress report video. Two comments if I may?
1. Put a heat sink on the L289N;
2. The L289N will not operate the best it can in voltage drive mode as you have it now because the voltage is too low and the current flowing is too high for too long so it overheats. You need to control it using the L6506 so that using the voltage chopping technique inside the 6506 the 289 will drive the coils of the stepper motor with constant current albeit the value of this constant current can be varied by varying threshold voltages values at which the higher voltage motor supply is turned on and off ie chopped.
Here is a clearer diagram of chopped voltage waveform and resulting coil current waveform than my earlier electrical art - but not too dissimilar than my drawing I think you will agree😎 :
Chopper Drive
Relationship between voltage and current in a constant current (chopper) drive.
Image credit: Oriental Motor USA Corp.
Reactions: _q12x_
It is Under-Powered/Voltage. No need at this testing stage. I was aiming for its safe zone of operation.
And I find it to be at 3.3V. Over that, will heat up. But also depends on the motor used as well. For the scrapped motor will be a bit higher, 4V running cold. ;)
Not correct. It is Under-Powered Under-Voltage. It is as I tell you, running cold a these safe values. What you dont know is that the voltage and current are proportional. Meaning, as long as I increase the voltage, the current will increase as well. And vice-versa(but I don't have this capability). I tested at 3.3V and 4V for about 10minutes and all this time, run cold. No current too high as you say.
Heating occurs over a certain voltage but everything remains constant beyond 10 seconds of running.
Yah... thats the next thing in plan. I do not have this chip and it adds too much to my budget expenses. And also will be used sporadically. So my plan is to actually make it's internal cct that consists of 2 opamps, a FF and a clock. Easy to make, but a bit spacey. I can live with that.
I leave you with somethings to ponder - why does your current project spin the motor slowly and smoothly albeit in steps but when you increase the pulse rate it stops rotating? And you may notice that over the range the motor spins as the rotational speed rises the torque the motor is producing decreases - why?
That is the nature of a stepper motor. The higher the frequency the smaller the torque. And vice-versa, the smaller the speed, the higher the torque. Is nothing to wonder about. Is like looking at the sky and ask me why the clouds are moving. Because thats the way sky works. The same as with the stepper. And the faster the fv applied to the coils, the faster it runs. But in a certain limit. After that limit, or certain fv, the stepper is unable to spin anymore, and losses its rithm. I already establish these limits.
How is your progress? Did you managed to make the motor spin?
Regret not even started yet.
Reactions: _q12x_
_q12x_
New York
United States of America
About Stepper Motors
_q12x_,
marconi,
