thanks all. i understood the back was missing, just wasnt sure if anything internal was missing
It won't matter as the replacement plug will come with all the required parts.
My first post was rather harsh as I assumed this was a troll post... And by I needs to be replaced should have been it needs to be replaced! (I hope I don't need replacing yet!)
What the heck happened to that plug top , looks like someone has taken a multi-tool to it to create that near perfect V shape
Must be a wind up , Shirley
That was part of how I ended up guessing a sandwich toaster, I think the plug was left on it while cooling down, hence the nice symmetrical shape.
I've had one break in a similar manner.
Centre of V is retaining screw and gripping sides of plug to pull out means it breaks upwards from that centre point. There was another recent thread showing something similar, so I'd put it down to the usual combination of poor design and manufacture, combined with inferior choice of material.
This has to be a wind up!
You wouldn't even get that plug into a socket without physically pushing on the bare metal at the back of both the live and neutral pins.
I have seen broken plug tops is service with damaged backs and even with NO back 😬 but never one like that with a perfect V carved out the back
But as mentioned above it could be melted by leaving on top of the toaster maker
It was actually very easy to push in just by holding the sides. the switch was off anyway thank god
