M
Matteh
Hey all,
First post but have read up a lot over the last few months as I have been prepping for my AM2s which I sat last week and thought I done well on,
Good news is that I only failed on 2 sub sections of my install, the ring circuit and the heating system, neither of which are circuits I do at my own place of work so not used to them.
My question is really about the wording of the feedback I received on my results, as it states that “The installed circuit was not completed to a fully functioning standard” but surely this isn’t the case if when testing my own rig, I got my results and have passed the testing and inspection part?
I have attached a screenshot with said feedback, any help is much appreciated!
TL;DR
Failed 2 sections in AM2s, confused about feedback
Deciphering the jargon,, it's pointing to issues with following the prescribed specification; this can installation; conductor sizes, protective devices, routing, terminal allocation or certification; it may well be the spec says to test in a nonstandard order and not CRIPPLER etc that we get drilled into us.
Reactions: nicebutdim
Upvote 0
Thanks for replying,
As for the spec I can only think that it’s because I used 2.5 cpc instead of 1.5 but our assessor told us we could do that as 1.5 was just the minimum, I will use 1.5 on my resit though just to cover my arse, bit annoying though!
After speaking to a college friend he asked if I checked the fuses in the spurs to see what size they were and I did not, I just saw them in there and stupidly assumed they were fine, an expensive mistake to make unfortunately.
Upvote 0
Am2 is little to do with practical knowledge and more to do with following a wiring diagram, you may well have wired it correct but if it is not to their wiring diagram it will fail.
Upvote 0
AM2s results question
Matteh,
Matteh,
Electrical Courses
