Discuss Wanted, 2.5inch IDE hdd in the For Sale and Wanted Forum area at ElectriciansForums.net
James
Mentor
Supporter
Patron
I am in need of a hard drive,
needs to be the following specs
ide interface only, can’t have sata
1Gb or lower capacuity.
I can’t find any new drives of that spec, the lowest I am finding is in the 100’s of Gb and the interface can’t take it.
I have been banging my head against this machine problem for nearly a week now and this seems to be my final hurdle.
p.s. If anyone ever asks you to fix anything involving an old operating system by IBM called OS2
steer well clear if you want to keep your sanity!!
You've got little to zero chance of finding a drive that small unfortunately, if you do, the chances of it being a good long term solution is slim, you'd be better off upgrading the entire machine.
customer is not spending £90k on a new custom cnc control system.
however, i might have found a solution.
it was an example of what is available, trying to find the same or similar in a qty of 1 and in the uk.
I think I've got a few of them used but good.
Message me if you need one sent.
Reply to Wanted, 2.5inch IDE hdd in the For Sale and Wanted Forum area at ElectriciansForums.net
I've managed to mainly fix a Megger 1502 MFT that was so far out of calibration it got laughed out of a tester day. I have high current loop. rcd...
About a week ago when I turned on the bedroom light (loft conversion) there was a BANG from the light fitting right up in the vaulted ceiling...
4K
Hi, We are designing and building cooking gas bottles with electronics controlled valves. These are for kids camping chalets. Its purely a...
Hi all, I appreciate that this is a question that has been answered a lot but each response I could find was for slightly different set up to...
L
:)Hi everyone.:) I use the forums a bit so thought it would be the ideal place and audience to put this to. Finaly after a bit of deliberation...
lloyd1980
L
