Discuss What size crimps in the UK Electrical Forum area at ElectriciansForums.net
Most wholesalers will do a variety box of bootlace ferrules then you just need the tool. Some manufacturers vary the size of flylead according to the device rating so could be 2,5, 4.0, 6.0 etc...
the ones I used for the last job, Green ones but I cant find just those and I cant find even one to try and size it
grey gray gray gray 4mm .
This . Yet Ive seen people just cut them sort and not use a Ferrule
you could double the flex over ,but it would not show you are a professional spark ,the last inspection the idiot says those are nice .what biscuits or tea .
Ferrule kit and self-adjusting crimper in Lidl just now for £15 or so. What not to like?
The colour tells you the ferrule size BUT there are two standards (at least) in use! Some RCBO have different flying lead sizes but likely going to be 2.5mm - 6mm range, strip one, see if it matches a ferrule, crimp said ferrule on and see if it holds.
Reply to What size crimps in the UK Electrical Forum area at ElectriciansForums.net
Hi just wondering if someone can help me. I have an rcbo that keeps tripping but only when the fly earth and neutral lead on the bars it trips...
Hi , I’m going install a commercial 450mm extractor fan , what size and type of cable should i use ?
Hi, I have always used banjos when earthing the armour on an SWA but have now switched to earthing nuts. I am making off a 10mm fly lead to the...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind...
