Most wholesalers will do a variety box of bootlace ferrules then you just need the tool. Some manufacturers vary the size of flylead according to the device rating so could be 2,5, 4.0, 6.0 etc...
Reactions: SJD and SparkyChick
use the grey ferrules for fly leads .
the ones I used for the last job, Green ones but I cant find just those and I cant find even one to try and size it
grey gray gray gray 4mm .
This . Yet Ive seen people just cut them sort and not use a Ferrule
you could double the flex over ,but it would not show you are a professional spark ,the last inspection the idiot says those are nice .what biscuits or tea .
Ferrule kit and self-adjusting crimper in Lidl just now for £15 or so. What not to like?
The colour tells you the ferrule size BUT there are two standards (at least) in use! Some RCBO have different flying lead sizes but likely going to be 2.5mm - 6mm range, strip one, see if it matches a ferrule, crimp said ferrule on and see if it holds.
the pict
Mentor
Brodick
Business Name
Devlin Maguire Electrical
What size crimps
the pict,
pc1966,
