Discuss Help with a vintage doorbell and wiring in the DIY Electrical Advice area at ElectriciansForums.net
NicoNix
Help please!
Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even drawing on the photos to show me!
I’m a DIYer, very aware of health and safety with electrics, busy renovating an old property. I’ve put lights in/added sockets etc.
What I know… mains to a transformer to the button (don’t have one yet but know it comes in different voltages) to the bell and back to transformer. Not sure on what type of transformer.
If anyone can make this simpler to understand. Please help.
Gavin
TL;DR
Help wiring a 230v vintage bell as a doorbell
its a mains voltage supplied bell.... i would say a school bell?
it says 200/250v on the cover
You cant use a regular doorbell button... not rated for that voltage.
You can get "retractive" switches that operate 230v, look like a lightswitch... but you would have to source a weatherproof one if going outside.
Save a bit of hassle and buy a regular "ding dong" from screwfix.... Comesin a kitwith a load of bellwire. Might need to get a seperate transformer though.
looks like a very old class change bell from a school premises, personally I wouldn't use it, I am sure it can be made to work but we are in 2024 and there are many better options for a door bell.
Operated by a solenoid. Mains on pulls the hammer in as soon as this happens the circuit is broken, when it returns the circuit makes and on goes the cycle hence the ringing of the bell. Turn the dome to adjust the tone as the fixing bolt is off centre, going to be loud.
Thanks for the reply, I just need to find something that has this exact bell sound but something I can use as a doorbell. Hard to search for a sound haha
Yeah I get that thanks for the reply. Just need to find a doorbell that has the same ring. Hard to search for a sound haha
Thanks for the reply. Any idea of something you could recommend that has a similar old style ring. Hard to search for something with just an idea of a sound
What about one of these? They run at a safer voltage than the one you have;
Reply to Help with a vintage doorbell and wiring in the DIY Electrical Advice area at ElectriciansForums.net
I’m trying to install my Ring doorbell (2nd gen) and I’ve discovered that the transformer feeding my Freidland isn’t producing any power. I...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi, I bought a Ring wired bell thinking, easy, just replace the current doorbell. Now I'm hunting down how to bypass the chime but am unsure of...
Hi. I have a blink video doorbell and want to connect a 12v mechanical bell (pic attached below). I know Blink only allow 16v-24v AC transformers...
