Hi has anyone on here got any knowledge of the wiring system in Tenerife is it anything like the UK or is it like opening a bag of worms ?
The reason I ask is I have a cousin there who wants a few things looked at and it’s giving me a free holiday. But am I going to find things straight forward or spend more time testing it than site seeing ?
Any advise from any in the know would be great thanks in advance and no I’m not needing a spare hand for a free holiday the wife will be there for that ! Lol
I expect it to be the same as many European countries, and they use copious amounts of radial circuits. No rings.
Maybe different cable design/ containment… but it’s just same live, neutral, earth…
The preferred method of installing cable through most of Europe is in trunking.
I mostly saw copex in southern spain when I lived/worked there...30 years ago mind lol. The basics are the same though. All radials. No rings as said. You can and do have things like washing machines in bathrooms (well it was commonplace back then anyway).
There was a certain simplicity to everything.
I do have a little, limited experience of Spanish wiring systems in domestic properties, not specifically Tenerife though but I expect it's much the same everywhere.
The points already mentioned are spot-on, namely a lot of cabling in conduit and radials for everything. Lighting conduit tends to be the spiral-wound type and quite small. I don't know if they have prescribed zones or not, but I doubt it.
In some properties you will find plastic cover plates scattered around the walls, and removing these will reveal junctions which can give a clue to how the cables are routed.
Many houses are built of hollow concrete blocks and you may find the cavities house wiring and plumbing. Faced with these walls, solid and tiled floors and solid ceilings it can be very tricky to add new circuits and I've seen a few additions done in white trunking as most of the walls are painted white. If you have vaulted ceilings with exposed beams then you have extra scope for additional circuit placement.
The good news is that the Spanish have no fear about breaking into walls or even lifting tiles and making good afterwards, just as we have no problem with breaking into plasterboard walls and lifting floorboards.
Some very modern properties, especially commercial ones, have stud wals with plasterboard over which makes their wiring much more similar to ours, but these are relatively rare.
Wiring is almost always in singles, and the only T&E you will find will be flex.
Single RCD boards are commonplace in older properties and yes, a washing machine in the bathroom is very common. My neighbour has a socket next to her wash hand basin and the light switch is not only inside the bathroom but actually in the shower enclosure!
Tip: If the kitchen sockets are tripping it's almost always the kettle at fault!
Thanks that was what I was looking for someone who had actual experience!
I wasn’t sure what I may find I was imagining all white wires and no markings and having to test everything lol I guess I always look for the worst so that when I see the job I am then pleasantly surprised !
Thanks!
I am not sure of the regulations in Tenerife, as others have said no FRC's, wired in singles inside flexible plastic spiral conduit In most of the EU (France and Germany) there is a maximum of eight dual pole MCB's to an RCD, domestic appliances and water heater will be on their own radial, sockets will be restricted in number for the size of cable (France is 12 x 2.5, 8 x 1.5) Lighting circuits will possibly be by latching relay's hence two wire at the switch, rural properties will be TT and you could have a domestic three phase supply into the property.
Following all the rules for a three phase domestic supply in France I ended up with a four row by thirteen consumer unit in Germany it would have been by twelve, but still with the same restrictions as above. DSC02264.jpg
Sadly, I don't think my Spanish is good enough to understand the technical bits, and being an e-book is not so handy for me.
I'm still learning the language, slowly, but I doubt if "dos cervezas por favor" will cut it!
I was in the same boat at first with my French, I found that this book: L'installation électrique - David Fedullo , Thierry Gallauziaux -... - Librairie Eyrolles - https://www.eyrolles.com/Loisirs/Livre/l-installation-electrique-9782416000058/ was so profusely illustrated I was able to understand what the text was trying to explain, eventually I found I did not need the text as the illustrations indicated all I needed to know, without looking inside the Spanish equivalent difficult to say if it would be helpful or not, but thought it worth a post, not forgetting both countries are in the EU and the Regulations are possibly the same, or very close.
One thing I do know is the same is the power supply is through an RCD that is current set, so if you go over your paid for tariff it will switch off, can seem like a fault, but is not, worth being aware of.
That's very interesting. Not sure I'd be doing much work except replacing like for like, because the electricians close to me are very reasonable with their charges.
I did not know about current limited RCDs. I will have to check my contract for this. I renewed the supply contract last year so will dig it out next time I am over there.
I do know that shortly before I bought the place the supply cable had been upgraded. All has been fine, but then I don't plug in welding gear or other heavy use items!
The current limiting RCD used to trip during the day for no apparent reason until I dealt into the electrics and realised that the water heater was not time controlled, but on 24/7, put it on a timed control for overnight only use and that problem went away, our water heater was single phase although the supply into our property was three phase, others I know have three phase water heaters, in Spain and Tenerife I would assume the tank is on the roof using solar gain mostly.
Yes, my water heater is also on 24/7 when I am there, but your suggestion of putting it on a timer is one I will attend to next visit, as electricity is very expensive there. I didn't do this before as I used to rent it out during the Summer and a family of four needed plenty of hot water for showering etc. but I'm usually there on my own now so an hour a day/night will be fine for my needs, once I have had it on for a day on arrival just to get the tank up to temperature.
I had my immersion heater here in UK on 24/7 for a while but fitted a new timer and noiceably reduced my electricity costs. It now comes on for an hour in the morning but still within off-peak hours and that gives me what I need on a daily basis, with the occasional boost if I have guests.
