- Aug 12, 2017
- 14,313
- 20,712
- 3,557,381
- 51
- United Kingdom
Ive been asked to replace a cooker hood thats gone "pop" and just by speaking to the customer on the phone, i think i know why.
Apparently, the ducting goes straight up, and through the roof... Not sure if its a bungelow, or goes another storey before going out the roof.
To me, i expect the hot air is cooling, condensing onto the duct as grease, and running straight back down into the hood. Unless a vertical run is permitted, and its just old age thats caused the failure.
Ill check how greasy the duct is when i go to see the job.
All i can find online installation manuals state 3m max ducting length, but doesnt specify horizontal or vertical.... and max 3 bends. (Howdens, Lomona model hoods)
I know the hood cannot be ducted straight out the wall, as there is a garage there... but maybe could go into the garage, then right angle bend, straight horizontal run to nearest outside wall.
Or block off vents and just use it as recirculating.
