Has anyone had any issues with NEXT wall lights being faulty and blowing at lampholder, leaving the fitting damaged?
Had 3 in a row which seems strange....circuit been tested and not tripping at source.
3 in a row seems a real coincidence.
Is the failure due to heat ? Are they Led lamps or incandescent.
Are they cheep imported lamps?
I would always fit branded lamps in any fitting I install.
The extra £ per lamp is easier to absorb than a call out to investigate or repair a fault.
Can you explain what you mean by 'blowing at lampholder'?
Some pictures of the problem would certainly help.
'blowing' is a non-technical term with no defined meaning so could be any number of things.
