Hi
can you help ?
I have a wooden table in my living room where a desktop PC is and a monitor on top of it
Today I touched something metallic that was resting on the table and I felt a little tingling sensation
I went to get my multimeter (very basic cheap multimeeter) and I grabed one of the probes with my hand and touched that metalic part that was resting on the table and it read 60v AC
Just touching the table wood on itself reads 27v ac
I disconnected the cables from the monitor that was on top of the HP desktop PC and the voltage droped to 5-6v
In any way I or the metal object was touching the PC or the monitor
What the hell is going on ? Is the voltage coming from the ground ? I was wearing sleepers
can this "stray" voltage be harmful for example to handle electronic components ?
thank you
It's usual for electronic products, particularly IT, telecomms, radio etc. equipment, to have interference suppression/ electromagnetic radiation filters in their mains circuit, typically including capacitors connected to the device 'ground' or metalwork, even when the product doesn't require an earth connection.
The type (ie safety) and value of such capacitors are chosen so the current is small, and not harmful, but does still create a tingling or 'buzzing' sensation on one's skin! These capacitors are often wired between live, neutral and earth, and this can create a potential divider giving half mains voltage at the equipment 'ground', so with a 220V supply you might see a voltage of 110V on any equipments non-earthed 'earth' (which could include the metalwork/ body of USB, HDMI, jack or co-ax connectors)
You don't necessarily have anything wrong, but worth checking to see if your monitor or PC need an earth wire, and if it is connected through to your mains supply earth (if you have one). Much equipment these days doesn't have an earth connection, but that can often result in the effects you are seeing!
The usual danger to electronic components is through electrostatic discharge, where many thousands of volts build up on a person due to clothing material, and/or insulating footwear, so when the person touches a semiconductor pin, the 'zap' can break down the device junction. Your measurements are of modest voltages and hopefully limited current, but if you are handling semiconductor components or circuit boards, you should be taking static precautions, eg using an earthing mat, wrist strap etc etc. and doing your best to reduce the voltage on your work area.
If your home has an earth connection, use that. If it doesn't, maybe a good idea to bang an earth stake in the ground!
I had a situation in a previous house where the earth relied on the main water pipe. At some point, the pipe in from the street was replaced by plastic. Result: house had no earth! Only a tingle off the (thankfully otherwise safe) washing machine alerted me to the problem. Scary!
