It's all part of the dwelling.
But just because it’s part of a dwelling, are we saying it must be considered household and similar use?
I can assure you that if I put a potters wheel and kiln in the lounge, my wife would not consider it household use.
Maybe if you just use something like this, that can be pad-locked off, all should be good.
But wouldn't it be a safer departure from BS7671 than using a socket?
If you can prove your departure is of the same level of safety as it would be by following the Regulations then it is fine. There is a reason departures are best avoided, if something goes wrong your only back up is your decision and reasons for doing so.
