Hello all,
I have a multi-faceted question for you.
I have just completed my Level 3 C&G 2365, and am currently studying for my 2391-52.
A friend asked me if I could install electrics in their campervan. From what I've been able to see, there's specific regs around "Moveable installations", which I think this would come under (Section 717). Nothing too chunky, 230V max.
The main thrust of this question is: at what point does it need to be certified by a CPS-listed person?
Is it installing it at all, or is it if the client decides to install an external hookup?
Because if they are just planning on using a leisure battery, I can use an inverter and then run any sockets and lights off that, however I know that the work will need to be checked by a CPS if the installation will be connected to an external installation like a campervan park because any wrong wiring/ major cockups could potentially affect the rest of the campervan installation.
I spoke to one of my tutors and he doesn't think so? It's a bit of a grey area in terms of needing to certified/ able to self-certify.
If something is in BS7671's Special Locations do I need to be a certified CPS member?
There's a few unknowns, like specific usage, but I will ask them once I have a more solid answer.
If anyone has advice/ previous experience or useful sources of information that would be excellent.
Many thanks,
TL;DR
Do I need to be a part of a CPS to install campervan electrics?
Hello all,
Many thanks,
Can I ask, whether you have any Electrical background/ knowledge (competency). And what type of Electrical Load/ Draw, will your Motorhome require. We’ve done a few of these. (Mainly for Mobile Dog grooming). YES their are I.E.T BS7671 standards laid out for this. (The Earthing requirements are the biggest issues).
I do have electrical experience, mainly minor electrical work, swapping things like for like and installing a different light fixture and some small fault finding/ replacement of accessories on power ring circuits.
Yeah, I've had a look through the regulations and have found the relevant chapter.
I have heard back from my friend, the most intensive draw is going to come from a laptop charger. No electric shower. And they've clarified no hookup.
This is all in the hypothetical stage right now.
Oh, and I also have a labourer's ECS card
ALL GOOD..! You said you’d spoken to your Tutor, so I take it your on your Level 2 or 3. (Install an angled Make Blue 32 Universal externally. An IP Mini DB with 40ampDP, 3xRCBOs. Run all cabling in FP). Discuss it with the Mentor, you’ve done all this work for and ask him to sign it off.!👍
Apologies, I don't quite understand.
The person who asked if I can do this isn't an electrician, and I've completed my Level 3.
So your recommendation is a Mini DB protected by a 40amp protective device and then 3x RCBOs, and run all the cabling in FP200?
From your answer, I'm getting that I need to be certified to create an EIC, or get a registered person to verify my work?
A camper van will fall under Section 721 and contained in there is the type of wiring you can use. FP up to 2.5mm² is not flexible and not appropriate, do not use FP.
I agree that using FP seems inappropriate.
Thank you for clarifying the difference between transportable unit (like a broadcast truck) and a 'motor caravan' which is what this would be, so Section 721 is what I need to look at.
Okie doke, would you mind answering a question?
Would I need to be certified (as in part of a CPS) to install and test this installation?
Because if so I will tell my friend that she might as well hire a spark that can install, test and certify all in one whack rather than having to hire two people.
A mobile campervan does not fall under the scope of Part P. You should be able to do this and issue an EIC but I would be wary of doing so unless you have liability insurance should something go wrong.
If you are expecting to Sleep in the Vehicle. FP flex is high recommend (as it’s flexible enough for the job)..! SAFETY FIRST every time. 👍
It’s not FP200 it’s the latest.! (Out of interest, which Level 3 course have you done). Was it the 42months [3&half yr] Full Apprenticeship… OR the FAST TRACK [3week- ‘BODGET & Scarper’ Special].???? Don’t forget in the Planning and Design stage, The Future Prospecting of the hid/design/install. As People may very well be Sleeping in the vehicle. SAFETY FIRST, hence why I’d recommend FP etc..! (Up to you, as I’m not sleeping in it).👍👍👍
I’m imagining Power/Lights/Cooker/Heater/SPARE👍👍👍
Can you show the type of cable you are referring to just quoting FP leads people to think FP200.
