Following on from my #12, exposed live contacts if just the clippy on bit is plugged in…
I found a broken adaptor at somewhere I’m working….
That’s the two halves. The clippy on piece is standing on the pins behind. You can see the metal contacts which meet the sprung contacts on the other part when clipped together.
Ok, there’s some thin plastic ridges, you can’t touch metal with a finger… but any thin metallic object could slide down and touch.
There’s no mechanism that switches those contacts on only IF the assembly is clipped in place.
That's dreadful.
Until Steve started this post I've never actually seen one come apart, so hopefully it's a rareity.
That's quite normal. I've seen quite a few chargers/adaptors like that. It's made like that so they can fit various 'plug' sections to suit different countries. Most of the ones I've seen have a 'push down' clip which lets you unclip the plug section fron the charger.
so it's not even broken? It's made to be detached, leaving live metal if plugged in.
I agree that Steves is broken but the 'base' is meant to be interchangeable. You can see the word 'open' on the main charger which would allow the base to unclip and a different style to clip on. I'm suprised they didn't just send out that part.
If I remember when I get back off holiday I'll take photos of some of the chargers I have that have interchangable bases.
