maybe it's just me !
Still sussing it out.
So if plug directly in to A port of usb plug socket - display lights up showing volts
whereas if plug into the C port nothing comes up. Only way to get reading is plug a load in on other side 🧐
Mine's the same, though I hadn't realised that until I just tried it.
You need the load (just for the USB C, not the A) and then it lights up!
Doesn't seem to me to be a fault, as the whole point is for it to measure performance when monitoring a load!
ok thanks for checking.... all good then, neat little tester actually
In theory, you have the right tool to put in your Click USB sockets in your clients kitchen, get your client to plug in her phone (needing charging) and compare the watts from that, to her charger watts in the 13A kitchen socket and to her charger watts in other rooms! A lot depends on how charged-up her phone is at the time. Having it partly discharged (certainly well below 80%) when doing this experiment would be best - might you possibly be able to ask/ arrange that??
if your client's phone is an older model with a USB-A charger, all the readings should be very similar
Ok thank you...... appreciate your tips
Well here's another nugget -
There is a good reason why the Yojock tester doesn't light up when you plug it in:
USB A sockets on a faceplate have 5V on them permanently, even before you plug anything in.
USB C sockets have zero volts on them when there's no load. It's a safety feature - part of the USB C spec.
A load needs to be attached before the socket turns on (at 5V) and then PD negotiation starts between the load and the supply. You can see that happen after a few seconds on the tester. The Yojock takes so little current on its own that it doesn't turn the power on.
So there is nothing at all wrong with the testers we have 🤪
Evening Guys.... did go along yesterday and check out.
Nothing too exciting Im afraid!
Turns out any socket she plugged into phone was charging slower than expected.
Went round to every socket with Megger 1st just seeing what mains voltage was and quick zs.
Nothing out of the ordinary, since we'd last tested on 1st visit.
Then same again with the USB tester.
1st round with my 70% charged mobile reading around 5v.
Then customers mobile again around 5v.
Did also try with couple of different leads.
So came to the conclusion that it was more than likely her mobile playing up.
Just coincidental happened similar time to us changing faceplates.
Faceplates won't change charging speed on their own, so it's almost certainly the charger or cable, or the phone itself (battery health, an update, optimised charging switched on). Worth testing her charger on another socket in a different room, and another phone on that kitchen ring. Whatever you find, note it down with a photo and send her a short written summary, it saves arguments later about what was or wasn't part of the job.
Well I am very impressed at how far you've gone to satisfy the customer.. well done!
So many customers think something has gone wrong with the cooker or lights or shaver socket etc etc etc, when all you've done is change a socket. 'But it was fine before you came'. :D
I think they perhaps become hyper vigilant of all electrics when the electrician is around, and suddenly notice anything that hasn't been working properly for some time
If a faceplate incorporates USB C Power Delivery electronics, it will change charging speed on its own! From 2024 (and still in progress) the EU has mandated USB-C with PD as the standard. But we've left the EU, so we are not compelled to follow, though I think it's inevitable PD will become universal.
Edit: I believe the directive applies only to the devices consuming power, it doesn't mandate USB-C or PD for faceplates etc, though they are more available now.
But you are correct in the OP's case, all faceplates were 5V, and the tests conducted, along the lines you suggest, revealed there was no difference between sockets or rooms. Only that the customers phone battery seems to be on it's way out!
The saga of device charging standards is a long read
I'd love to hear @sythai explaining all of this to the customers blank face.
I'd just plug me own dead-phone on an ultra fast charger in the same socket, and then sit back for 30 mins enjoying a hot coffee, and then show its fully charged, and walk away. End of.
Sometimes you have to be the strict teacher, if you allow the old 'customer is always right' nonsense hit you, you'll be wasting time with no end in sight, hits our pockets more than its worth.
