Colin33
Hi all, I'm trying to get 3 x 4mm stranded conductors into a double metal-clad socket. Does anyone know a brand of metal-clad with terminals big enough for this, and the space to allow two top and one side gland into the unit?
Might be better going into an adaptable box for the joint first, and then into the socket.
Yes, would be the easiest option but I'm limited for space so getting all into one box would be better if possible. Google recommends the MK K2946ALM, so unless someone recommends something else I may give the MK a try...
I would have thought they would go into most sockets just don't twist them.
I've been trying to get them into some cheap sockets that were supplied to me, absolutely impossible, I think they're only designed for 3 x 2.5 or 2 x 4mm. And even if I could get the conductors in, the unit won't fit back into the box as they wont clear the back nut on the stuffing gland.. bloody 'designers' !
Into a wago 2773-404 then 1 into the socket
The MK "Metalclad Plus" K2946ALM does indeed accommodate your cable, and will apparently even accommodate 3 x 6mm stranded
