LukeD
How do you find wagos for value for money etc ?
I have used connection strip blocks for years and have never worried about the costs etc !
Now these guys pop up on the radar ! I seen some other "one time " use versions as well as the lever type wego . For access etc i can see they are great .... But its the cost thing !!
What other similar connectors are worth looking at ?
cheers
same as phil7677, connection strip blocks? oh yeah those old things!!
Helacons and wagobox are always in stock in my van, hate to think of running out of them.
wagos are great, they are dearer than junction boxes, but are maintenance free, the time they save make them worth while. and the wires never pop out, unlike connector blocks
the amount of blocks i have had where the screws have snapped etc never used one since the good old fast fit solutions
Only issues i can see are
1: No test access on the Helacons ?
2.Having to cut back and trim if changing etc ?
3: Access if you need to cut a centre cable , There is not a lot of room !
Just wondering if Wago leaver types are more "user friendly" /
years ago..... i had so much to do on a friday night ! Now its paper work and a little internet !
the helacons i have, have a test point in them. the wago levers are ok aswell. if you want to get the cables out a little wiggle will do it without having to trim back
I have just bought a contractors starter pack from Wagobox Home of The Maintenance Free Junction Box, run by Ray & Paula (I think Ray is the guy who invented the WagoBox enclosure). It was £99 + VAT but after seeing a guy using them on site last week, I decided I had to get with the times. They arrived today and I have played around with both the pushfit and lever types and they seem bombproof.
I stripped some 2.5 and inserted it into the push fit and you honestly cannot pull it out, however give it a little twist and it comes out with a little persuasion. My colleague thought I was mad buying them but after a few little tests today, the time I save will pay for them in weeks.
If you are registered with NIC etc you can apply for a free demo version to see how good they are. Or for £11+VAT they have a mini kit on the website with a few boxes and a good selection of connectors to start you off.
I spoke to Ray before buying as I was a bit unsure of the cost issue, but he is a great guy who is obviously passionate about his product and also the Wago's and after speaking to him, couldn't help getting my card out.
He has also put this video on youtube :
[video=youtube;xOZDLhRyE9c]http://www.youtube.com/watch?v=xOZDLhRyE9c[/video]
Can I also just add, I have absolutely no connection whatsoever with the company, just a very happy customer!!!
i took some samples of both types on site to show the lads, one big fella said they are rubbish i could pull that cable straight out of it :D:D guess who won the wager
I see so many advantages of using these fittings . Only issue would be softer multi strand cables ?
The wago box is a excellent idea , As long as they accept the Helacon units ?
I know what you mean Phil. I thought it would pull out with a bit of force but it just doesn't seem to budge. Also I took one to bits and it's very clever how it locks onto the core so it will not weaken over years. Very Very impressed.
P.S Where are the toolbag pictures :D?????
I sound like a rep now, for softer stranded cables just use the lever clamp models. I have terminated cat5e into it as a test.
:) will try to get them up over the weekend if i remember :) heads in books and laptops all the time. :)
I also use the wago's for ring testing and for R1+R2 and R1+Rn connections. However I find that the test hole is a bit too small for my probe tips even with the shrouds off, so I use two 3-port terminals rather than 2-port ones with an exta bit of cable to enable the probe connections to be made easily.
