B
bahco
few questions i need help with please lads
1 if you spur off a ring main with a fuse spur how many sockets can the spur feed?
2 if you fit fire rated downlights to the upstairs of a house how do you go on with the loft insulation regarding heat from the fitting, the tranny needing room etc
3 finally maybe a stupid quesion but i mainly do commercial work where i work, i had to fit some metal back box's today, i used a sds chisel and really struggled to get a socket and a spur next to each other straight any tips?
cheers lads
cheers lads
