i agree the internal tails take up too much space. it's to allow for flexibility in configuring ther circuits. any board will be awkward to fit the cover if the wall is uneven and the case distorts. had it on wylex and crabtree. but for the priceof a hi integ. bd. BG are good value.
i have spoken to the local BG technical bod, who says that BG are happy to receive feedback frfom electricians on their products, and will try and implement any suggested improvements.
I used some BG Nexus accessories on a job last November and had numerous troubles getting the conductors of T&E to clamp in the terminals correctly - a single conductor folded over was fine but for the usual two or occasional three conductors in a terminal, at least one of them would end up at the side of the screw with a poor connection.
Part of the job was in plastic conduit and I'd used 6491X singles. I didn't have any problems with those.
thus proving that the old stranded cable is superior to the solid crap we're forced to use today. bring back 7/029!
Central heating "wiring centres".
A glorified empty box that takes choc bloc with no cable grips, utter rubbish.
Just dont bother, I always use an adaptable box with din rail and stuffers.
Why is heating equipment pants to work with? Because its designed for plumbers by plumbers.
Thorsman press in gromets or they may have been called quick fit . Fitted quickly but fell out quicker.
10 way duel rcd BG board is very good value - nothing "British" about it though except the name -i hate tower PVC Tape as the quality seems to differ from good to toilet paper from month to month - use Niglon PVC tape once as an alternative .. never again
Tower cable clips, not the clips themselves but the nails that bend going into plywood. Maybe I should use a smaller hammer?
ANY insulation tape, used to be able to wrap insulation tape around a draw wire or rod nice and tight these days you stretch the tape a little bit and it just snaps!!
Bought a roll of insulation tape from s******x. Not sure what it was made from but breaks with a small amount of pressure. Never again.
I remember when wrapping tape was an artform. Could make it look like a well-gripped tennis racquet.
Green and yellow insulation tape from sc.....x that tears along the green and yellow lines as you unroll it, oh and cheap / decafe coffee from customers. pretty sure that is worse than tape
Sent from my HTC Desire S using Tapatalk 2
Big n Daft,
ipf,
