P
Paul Chick
Hi guys,
Ive got a few outside lights to wire in next weekend and was wondering what sort of flex would be durable enough to go from the galv 'T' box upto the lights?
Im looping the lights round in armoured flex through 'T' boxes because i obviously cant make of those connections within the light fittings themselves due to space and looking crap.
Cheers,
Paul
Before you do this, can i ask why galvanised boxes? I ask because ive just finished an ongoing job where posh flats had LED outside lights installed in the planters. After the first two years these lights started to trip. On coming into this we discovered all lights had been looped in using swa into 't' boxes galvanised, exactly how you plan. All connections where fine but the majority of boxes where flooded with water and had rusted away under the soil due to the lack of IP rating and sealant. We went in and changed the lights and all the junctiin boxes to IP rated boxes and wacked a load of sealant around all connections.
Sent from my GT-I9100 using Tapatalk
Obviously not installed correctly mate. If you terminate the cables right and use a good gasket you shouldn't have any issues. Plus the boxes are being fixed to a secure surface and not left lying around.
Cheers,
Paul
Hi guys,
Really!!, ....And what sort of depth are you burying these so-called armoured flexible cables??
Cheers,
Paul
For a start, as you have already been informed, Galv conduit boxes are not designed to be buried, they have no IP rating. In fact you shouldn't be burying any boxes that have not been designed to be buried.
So you think making connections off correctly and a bit of sealant and job's a good-un?? Wrong!! ....You've never heard about condensation then. A box sealed tight, will almost certainly produce condensation, you really need to fill the box and connections with a propriety box filling compound, to be sure of continued electrical soundness against corrosion and damp etc.
IMO, use IP rated adaptable boxes, the small Wiska boxes will do the job, then SWA cable between the boxes and H07 flexibles with stuffing glands out to the fitting. It usually works for me. Should give at least a 5 year maintenance free life.
Cheers,
Paul
All had gaskets mate but they dont have an IP rating therefore not suitable for the purpose.
54 has the right idea. But my company wouldnt pay the cost for a compound filler. So just IP boxes,
And a load of sealant. Wont last long!
well thats tight if em innit....how much is it?.....about £4 a stick?.......
If the boxes are not going to be buried then filling them with 'gunk' is an extra unnecessary cost.
You don't need a 'jelly' compound even when they are buried, just a good IP rated terminal box with some petroleum jelly around the SWA glands and some WD40 on the terminal blocks.
Adaptable boxes filled with jelly do fail and because they are non-maintainable have to be be ripped out. Better not to bury them at all.
True. But they had no choice but to bury them in stand alone planters. Horrible job because i had to physically climb into the planters to do some fiddly swa glands.
yeah well that aint as bad as this rented we went to up in harehills (leeds) the other day.....we literally had to "climb" into the living room at that place.....chuffin loads of 1s and 2s there n all....so we will have to go back once we get the goahead from the landlord.......but the way some of em live....its like a different world.....
You tried social housing yet Glenn? Some of the stuff I've seen there still makes me shudder now
