B
BillyH
I need to upgrade the bonding on a current installation but am having a problem locating exactly where to bond to. The consumer is in the cellar and so is the stop tap, however at some time in the past the pipe from the stop tap has been replaced with plastic, run across the wall and then disappears under a concrete floor. No one at the property knows where the platic ends and copper begins.All pipework throughout is copper except for the 3 mtrs from the incoming main.
Where would it be permissable to bond the 10 mm
I normally bond at the first accessable place if its not possible to do so at the stop tap, In some places people dont have a tap and only one is under the path outside, Have done this many times and my inspecting engineer has been happy with it. As long as its location is labelled at the board and on cert. If you are lucky enough on installations where the plumber has run plastic everywhere i try to ask for a foot of copper after the tap to bond to.
Why?...if it's all plastic there's nothing to bond.
The OP could test to establish whether the pipework even needs bonding...http://www.electriciansforums.net/e...ical-regulations/16558-extraneous-yes-no.html
Sometimes better to just do it. My assessor expects boiler pipework to be cross bonded whether I like it or not. Its an arguement thats been done many times onthis forum!
Doing it won't hurt i dont think, some may view it as a waste of time.
Me, i think it can be pleasing to look at if done with care and attention but then I'm a bit of a silly sod.
No,it's not better just to do it because your assessor insists...no assessor can mark you down because you refuse to apply his personal preferences...he can only mark you down for not compying with the regs.
In the post I quoted it would only be a mixture of copper and plastic due to the 1ft bit after the stopcock!:D
Yes fella, i got what you were saying and i know the reg but i'm with spartykus and just like to do it (if i can)
For a metre of 10mm its free. Dont get me wrong its no big issue and there are times on new build that I dont bother as no requirement its mainly on alterations where a new water supply has been brought in when it was lead etc and i know there is copper elsewhere. It then makes a good conversation with inspector if it gets pulled from the jobs iv'e done.
Due to the consumer unit being in the cellar and all the decor throughout the property being of a high standard, not to mention every bodies favorite (laminate floor) i cannot see an easy way, without damage to wire a 10mm.If i could locate a cold feed pipe somewhere to wire to,and then test at various points of exposed pipework in the house, would that be acceptable?
Is the suppliers side of the tap still in copper/lead or is this plastic too?​
Not sure, but if it was i cannot connect here because of the 3mts of plastic in between .Surely its the pipework within the property that needs earthing
