What does this mean?
VIR ( rubberinsulated) cable . might be perished at ends, where the air has got to it. doesn't mean the whole cable is shot.
DNO will come out and remove their fuse at 9.00am and return to replace within 15 minutes of your phone call.
And one of the biggest myths is that the DNO fuse does not fall out on its own.
Because it so obviously does - a lot!
nothing to electrics... it's only a few wires, innit?
if you've got an RCD fitted, no need to earth anything.
if you fit fire rated halogen downlights, you can smother them in insulation.
