La Poste ~ Jan 1, 2012 #76 GLENNSPARK said: VIR is always shot along its full length...... Click to expand... What does this mean?
telectrix ~ Mentor Arms Jan 1, 2012 #78 What does this mean? VIR ( rubberinsulated) cable . might be perished at ends, where the air has got to it. doesn't mean the whole cable is shot.
telectrix ~ Mentor Arms Jan 1, 2012 #80 DNO will come out and remove their fuse at 9.00am and return to replace within 15 minutes of your phone call.
R RogertheBodger Jan 1, 2012 #81 And one of the biggest myths is that the DNO fuse does not fall out on its own. Because it so obviously does - a lot!
DaveyD ~ Arms Jan 1, 2012 #83 If I get my house rewired I have been told I have to get all the sockets moved to >450mm and <1200mm
JD6400 ~ Mentor Arms Jan 1, 2012 #85 telectrix said: if you've got an RCD fitted, no need to earth anything. Click to expand... I thought we are only meant to be doing myths ! :rofl: Last edited: Jan 1, 2012
telectrix ~ Mentor Arms Jan 1, 2012 #87 if you fit fire rated halogen downlights, you can smother them in insulation.
