The RCD myth triumvirate:
1) When using an RCD as the protective device, the earth fault current is "automatically" limited to the rated residual current of the RCD.
2) In a TN system if Z[SUB]s[/SUB].I[SUB]Δn[/SUB]<=50V the touch voltages attained during an earth fault will not exceed 50V.
3) The rated residual operating current of an RCD intended to provide fault protection only must not exceed 30mA.
Without starting the whole debate again do a search on the forum for neutrals at switches you will find a lovely big debate on it.
pencilpusher,
pencilpusher,
