DurhamSparky
maybe one for the more industrial of us ..!??
im designing a job that will involve metal tray work about 130meters in total...??
im trying to decide on best cable to install for the environment.
it will be installed at a height of 6ft-7ft and will be in a manufacturing environment...? (although very clean)
im wanting to install in SWA 4mm 3 core to give me radial outlets at 32A
there will also be SWA 2.5mm 3 core for lighting and a futher 2.5 mm 3 core for Security Spurs
but the client keeps asking if SWA is essential as it wont get damaged..??
thoughts please.?
If it's not going to get damaged could you just use flex? To the untrained eye it looks the same.
Either that or something else entirely, eg singles in plastic trunking.
all depends on when the cables leave the tray for connection to accessories. how they are run down walls etc.
You could run flex, and then into either PVC or steel conduit down the walls ect.for a clean environment I'd go with PVC tube, as it's really cheap, very quick to install, and won't corrode is it's subjected to regular clean downs. Are you doing the tray?
That doesn't give much headroom ! I would have thought at least 8ft
thoughts please.?
You don't say what the likelihood of damage is or what type of manufacturing process is involved, if you used a pvc/pvc cable then you would probably need to use conduit or mini trunking to make the drops to the outlets look presentable and give the cable some protection
While the SWA would be a better job it seems these days it's never mind the quality what's the lowest cost and without any info on the site T&E would probably do the job but it's down to the extra conduit and fixings that would be needed and how the installation labour costs of the alternative methods compare
Hituf would be a good alternative to SWA providing the cable does not need mechanical protection. This can also be used for drops and cleated the same as SWA.
Manufacturing Unit is producing LCD Tv's...
The Tray will be wall mounted at 6-7ft on a breeze wall that is been constructed. (no need for head room)
the SWA will pass a forklift truck area although it will be ran in the "green" zone where the pedestrian walkway will be sited..
the drops will be to socket outlets along the walk way for cleaning and maintenance purposes.
my idea is to run 300mm tray with T offs and reduce the tray to 75mm for the outlets all in metal clad..
im sticking to my guns on this one chaps.
Yes im doing the tray work however i might look to pass it on to some one with more experience in it than me to get it right first time and on time!
you want a 110v 115mm grinder with a 1mm cutting disc. This will cut the tray no problem, andsave you a lot of time. Dont forget to buy galv spray, and spray anything you cut.
You can choose to buy the T-s, or make them, ive never looked at the cost, but with a grinder, its quick to make them. For brackets, you could use unistrut, or buy top hat brackets. i think top hat brackets will be cheaper.
When installing the tray, use decent joiners, and i would'nt bother with bonding leads, apart from where there is fresh air joins. If you attach a flying lead from your banjo's on the SWA, to the tray, then this will help reduce your Zs also.
I'm just scouting the Le grand cat to make a list longer than schindlers.
was going to use Strut but going for stand off brackets, but still need some to mount my EM flood lights up at height on girders..!
try cleveland cables for your tray and strut. Thats who the firm i work for use, and apparently theyre loads cheaper than anywhere else. Post a little drawing of the girders and position of your lights, and ill suggest some clamps for you to use. welcome to the world of metal munching.
cheers mate.! ive got some nice angles to get around a well! every 3 meters or so i have a girder that sticks out that i have to bend around.! should be a fun challenge! unless i can get the builder to build his wall level with the girders and then its a nice straight run..!! highly unlikely though never mind.
