I have just read some of your comments on other post and you are so negative,
What relevance has my negativity other threads to this one, where quick and poor quality training is concerned and DIYers are trying to bodge I will almost always be negative as it's destroying an industry I am quite passionate about.
The fact you come on here moaning that a spark has knocked back your work shows the level you are at, while there is often more than one solution to a job you find it hard to take that you picked the wrong one may be with a few pictures and or a site sketch you may have got a better answer to your original posted question
Alternatively try here for an answer to your problem mind reading forum - Google Search as we don't do it on this forum
Chill out where are not all ****s
I'm perfectly chilled if you don't like the heat move out of the engine room.
There is more to life. :carolers:
The fact you come on here moaning that a spark has knocked back your work shows the level you are at,"
If you did read the first post I made you would understand the level I am at. :50:
Do I? So what does " Am I barking up the wrong tree " mean?
The fact is I didnt want to question him just incase I was wrong so I posted on here before talking to him so I dont look like a pleb when I did.
Maybe you should start your own forum that is for fully qualified Electricians with experience members only.
Anyway I can see what type of person you are so what ever you reply to this I will not reply to that as I cant be bothered with it.
"There is more to life" :nopity:
Take care x
